gustca01
Aug 21, 2025Aspirant
Speed Issues RBR850
I have a verizon modem that gives 1GB up and down. When I wire into it I can confirm the speeds. When my RBR850 is connected to it, I only get 100MB up and down. Not sure why any advice? NOTE: On...
Aug 22, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
gustca01 wrote:I have a verizon modem that gives 1GB up and down. When I wire into it I can confirm the speeds. When my RBR850 is connected to it, I only get 100MB up and down. Not sure why any advice?
NOTE: On the port connections settings on the Verizon modem, it won't set to 1000 full duplex, just 100 full duplex. This only happens on the LAN connected to the RBR 850. Everything else does 1000 full duplex.
Is there a setting on the RBR850 that needs to be changed or something I'm not setting right?
gustca01
Aug 22, 2025Aspirant
The Firmware is: V7.2.7.15_5.1.16
The Modem is a Verizon CR1000A with Firmware 3.6.0.2_BD
The ONT is from Verizon. I can't find a model number on it. If it's helpful I can provide a serial number.
I have the 1GB fiber plan from Verizon. The setup is Street -> ONT -> Verizon Modem -> RBR8750
When I plug into the Modem or use the WiFi from it I get 800MB+ up/down speeds. Using the same cable, plugged into the 'Internet 2.5G/1G' port on the RBR850. I get 100MB up and down when plugged, on WIFI, and from the RBR850 speed test itself. Therefore I don't think its my cable, which is a CAT.6A.
- FURRYe38Aug 22, 2025Guru - Experienced User
What connection rate speed is seen on the RBRs web page ui on the Advanced tab and select Show Stats button for the WAN port? Should see 1000Mbps here.
So the CR1000A is a router, not a modem: https://www.verizon.com/support/verizon-router-cr1000a/
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
New: Static IP Address Configuration for AP Mode | NETGEAR CommunitiesGive #2 a try.
Something else to ask the ISP about, ask them if you can remove the CR1000A router and replace it with the Orbi RBR router.
- gustca01Sep 13, 2025Aspirant
I tried # 2 and got a new CR1000A.
Still not working. I know that if I plug my computer directly into the CR1000A then I get Full Duplex 1,000 Mbps. when the RBR850 is wired via CAT6 to the CR1000A it just give me Full Duplex 100 Mbps. This tells me that the CR1000A should work if the RBR850 could accept the higher speed. Is there a setting on it that would allow it to accept a faster connection?
- FURRYe38Sep 14, 2025Guru - Experienced User
Sounds like some interoperability issue at the CR level. The 850 supports 1000Mpbs as mine does this all day along.
Something you can try, get you a non managed 1Gb LAN switch, something like NGs GS105 or GS305. Install it in between the CR modem and the RBR. Only connect these two devices to this switch. Nothing else.
See if this changes anything. The switch will have LED indications for 100 or 1000Mbps speeds. You should see 1000Mbps between the two connected at the switch.
Or see if the ISP can help you remove the CR router and got directly with the RBR. You'll need to ask them about that though.
