gustca01
Aug 21, 2025Aspirant
Speed Issues RBR850
I have a verizon modem that gives 1GB up and down. When I wire into it I can confirm the speeds. When my RBR850 is connected to it, I only get 100MB up and down. Not sure why any advice? NOTE: On...
CrimpOn
Sep 13, 2025Guru - Experienced User
Ethernet hardware (the actual physical equipment) has a mechanism to detect the highest speed that the link between two Ethernet devices will support:
https://en.wikipedia.org/wiki/Autonegotiation
If the CR1000A reports that the port connected to the Orbi RBR850 has negotiated 100Mbps, the most common reason is something about the cable path between CR1000A and RBR850 is "not right". It could be
- There is something wrong with the actual cable
- There is something wrong with one of the RJ45 plugs on the ends of the cable.
- There is something wrong with one of the RJ45 jacks (CR1000A, RBR850)
The most common troubleshooting steps are:
- Replace the Ethernet cable with another cable.
- Physically examine the RJ45 jacks to see if one of those tiny gold wires is bent or misaligned.
As FURRYe38 pointed out, there is no obvious reason to keep the CR1000A unless:
- Verizon is providing telephone service.
- Verizon is providing television service.
