Foxes2015
Aug 26, 2021Aspirant
Speed Test Issues
I have a 1.2G internet from Xfinity and have the Orbi RBR750. Ever since I installed I had solid speeds and it used to report just under 1G internet on the speed tests. For the last 2 months that spee...
Sep 05, 2021Guru - Experienced User
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact Blanca_O and DarrenM and send them a PM and ask for the beta.
Good Luck.
SSEpochX
Sep 07, 2021Aspirant
I signed up for the forums just to find a solution to this problem.
I have a Orbi Router RBR750, after the update to V4.6.3.7_2.0.49, my wifi speeds are down to 20mbps, but I have 600mbps internet. I did confirm the satalite gets the correct bandwidth over the backbone, but not to the connected devices.
Not sure how to contact a person to get the beta firmware.
- FURRYe38Sep 07, 2021Guru - Experienced User
For user out of warranty, contact @Blanca_O and @DarrenM and send them a PM and ask for the beta.
