wilydru
Oct 08, 2024Aspirant
Sporadic connectivity Issues - RBR750
Hi, I've been having two strange issues with my orbi. They don't seem related, but they both lead me to believe something is up with my Orbi. Curious to know if anyone else has had this issue. I'...
Oct 10, 2024Guru - Experienced User
Does this happen with other browsers? MS Edge, Firefox or Opera?
Does this happen across difference PCs and laptops or devices?
Does this happen with both wireless and wired devices?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
wilydru
Oct 10, 2024Aspirant
Yes, this happens with other browsers. It happens even via command line.
Yes, this happens across all devices. PCs, laptops, cell phones, tablets
Yes, happens to both wireless and wired devices.
GigaPoint GP1101X
Yes, using a CAT6 cable. I've tried using multiple cables and all lead to the same outcome.
This happens on a wired device without a MAC address randomizer.
All are disabled.
- FURRYe38Oct 10, 2024Guru - Experienced User
Does your ISP support IPv6?
Is IPv6 enabled or disabled on the RBR?
I recommend re-loading v.21 back on the RBS first, then RBR lastly:
After the system has been update, power OFF the ONT and RBR and RBS for 1 minute then back ON.
Perform a Factory reset using the following PDF process:
Setup from scratch using a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Use MS Edge or Firefox for this.
Be sure to clear out all browser caches before entering the web page.
After all is set up again, try testing web sites.
Don't enable Access Controls, Armor, SPC or Traffic Meter.
I'd run a couple of speed tests as well from a wired PC using ooklas installable speed test app first.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
