zachg99
Dec 08, 2023Aspirant
SSID is Duplicate Please Change Error
So, I have the RBRE960 with the latest firmware (V7.2.6.21_5.0.20) running 2.4ghz, 5ghz, and 6ghz wifi. I'd like all three wifi networks to use the same SSID. This support article says that, by defau...
- Dec 08, 2023
The separate 6Ghz SSID can not be the same as the Main WiFi SSID. There is already a 6Ghz radio running on the main WIFI SSID. The separate 6Ghz has to be different.
Dec 08, 2023Guru - Experienced User
