zachg99
Dec 08, 2023Aspirant
SSID is Duplicate Please Change Error
So, I have the RBRE960 with the latest firmware (V7.2.6.21_5.0.20) running 2.4ghz, 5ghz, and 6ghz wifi. I'd like all three wifi networks to use the same SSID. This support article says that, by defau...
- Dec 08, 2023
The separate 6Ghz SSID can not be the same as the Main WiFi SSID. There is already a 6Ghz radio running on the main WIFI SSID. The separate 6Ghz has to be different.
Dec 08, 2023Guru - Experienced User
zachg99
OH!! I missed that, thank you. I saw the 2.4 and 5ghz check boxes above and didn't realize that also enabled the 6gz frequency.
I guess the other network is for a dedicated high speed connection over 6ghz where you know you'll be in range and need the higher speed.
Thank you for that explanation!
- FURRYe38Dec 08, 2023Guru - Experienced User
Yes the separate 6Ghz network was for user to enable specifically for 6Ghz supporting devices. You can enabled this or disable this. 6Ghz supporting devices should connect on the main SSID network on 6Ghz there as well.
Enjoy.
