wfhstar
Apr 04, 2023Follower
Starlink and Netgear Orbi RBK852/RBK853
Hi! There are a lot of posts in 2022 about using any of Orbi Mesh WIFI products with Starlink, but they are all a bit vague and perhaps now out of date. My use case is that I have Starlink, ...
Apr 04, 2023Guru - Experienced User
I think a non managed 1Gb switch is all that is needed to make the starlink adapter work with the Orbi. The switch goes in between the adapter and RBR. Nothing else connected to the switch. NG GS-105 should work
Also:
