OrbiStopped
Jun 16, 2022Aspirant
Still no fix for router login
I've tried re-starting with no fix. Can Netgear please get this resolved? This has been ongoing for months.
Did you try factory resetting?
- OrbiStoppedAspirantNo. If you read the article, they are supposed to be rolling out a fix that doesn’t require blowing up your system.
Yes they are. But if its not to your system yet (limited rollout) and you're wanting to fix it, many used the factory reset option in the article.
