Mastra11
Jul 04, 2025Apprentice
Strange behavior of orbi RBK753
Good morning, I have an orbi RBK753 system since 2021 and I have always found it good and let's say it worked well, sometimes I have to restart it but nothing major. The router and satellites have fi...
Mastra11
Jul 13, 2025Apprentice
Hi, the other day I had to restart it again for the same reason. I didn't do a reset, it's the last thing I want to do, also because the network works very well. But what do you think could it be? I've never activated the Netgear_guest network, in fact it's always disabled on the router. When I see it active, it's without any WPA protection, and when I try to connect, no devices connect, as if it were turned off, and in fact it is turned off on the router. Thanks.
Jul 14, 2025Guru - Experienced User
Does the front LED on the RBR turn PINK or blink white when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
You may need to factory reset and and setup from scratch on the system if this continues. If after that something still happens, you may need to update FW as well since your behind. I was hoping that you wouldn't need to however if after all troubleshooting has been exhausted, you may need to.
