CSSP
Jun 13, 2026Aspirant
Stuck at no internet connection
I’ve been trying to help my dad set up his Orbi system but I keep getting stuck at the exact same point. The model number, I believe, is RBK652S, but I may well be looking at the wrong thing. On the ...
CSSP
Jun 15, 2026Aspirant
muhammadammar23 wrote:Power cycle everything:
This was the first thing I tried, since it was what the app suggested.
muhammadammar23 wrote:Check the Ethernet connection:
I know this for a fact because the first time I went to set it up, I had the satellite instead of the router, so I know that once I had figured them out and switched them back, I was using the correct (yellow) port.
muhammadammar23 wrote:Modem lock-in:
There have never been any other additional devices like this on this wifi network.
muhammadammar23 wrote:Bypass the app:
This I will try next time I'm there.
muhammadammar23 wrote:ISP requirements:
This was the second thing the app suggested, which is why I checked that my network was DCHP, not PPPoE or static.
muhammadammar23 wrote:Factory reset:
The model is completely brand new. I took it out of the box myself.
muhammadammar23 wrote:What is the make/model of the modem?
Another commenter further up was able to correctly identify it as this model.
https://support.netgear.com/support/product/rbk652s
muhammadammar23 wrote:Does the Orbi Internet LED show a specific color (amber, magenta, etc.)?
I believe at this stage in the process it is white. Throughout the beginning the lights did everything the app said they should be doing, blinking when they were supposed to, being the right color, all that. And the light doesn't change color when the app announces that it wasn't able to connect.
muhammadammar23 wrote:Is the modem a standalone modem or a modem/router combo?
It is a combo, cox panoramic to be specific. I saw in other discussions that those can be extra finicky, but didn't see any concrete fixes for that.
- plemansJun 15, 2026Guru - Experienced User
We know the router is the rbk652s. But we need to know the modem/gateway that the router connects to. That is key when it comes to these issues.
So check what is providing the Orbi with internet and post the model number for that here.
