Loop24
Jun 09, 2025Aspirant
Sub network with an Orbi RBS350
Hello All, I'd need to benefit from your knowledge and experience for my project with a RBS350: i have a house with the WiFi router from my ISP, which bring a good coverage For another hous...
Loop24
Many thanks Furry for your quick reply and support, i'll try it.
i have a RBS, not a RBR. Would it work ?
Jun 09, 2025Guru - Experienced User
No, All RBS require connecting to a Orbi RBR unit. The main host router for Orbi. RBS won't connect or operate correctly otherwise.
