_Pigpen
Feb 16, 2023Aspirant
Sudden wireless devices speed drop
Hi all,
Background: I have a 1Gb/s connection with ethernet straight into my apartment. The apartment is very old and has thick, brick walls and is a stupid shape, so I got an RBR750 and satellite, set it all up with a wireless backhaul as I didn't want to drill through a bunch of walls and everything was good.
Issue: In the last few weeks all wireless devices have dropped their connection speed from >700mb/s to ~300 to 400mb/s. The devices are Win10, Win11, ChromeOS, IOS and Android. Plugging a device into the RBR with ethernet gets a good result of ~900mb/s. The very weird thing is that I have a NAS connected to the satellite (wireless backhaul) with ethernet and that gets > 750mb/s when downloading.
What could be causing this?
Thanks for any help or pointers.
Wireless is sensitive to distance and building materials. 5ghz drops of much quicker than 2.4ghz. Plus brick will block its signal quite a bit. that 300-400mbps is about reasonable unless you're sitting right next to the router/satellite without intererence.
- _PigpenAspirant
Thanks for the reply.
The speed drop is 'everywhere' whether I am next to the router or satellite or a distance away. I do realise I am beeing 'greedy' and that the speed is fine for every day use. It's just bugging me 🙂
Thanks again- plemansGuru - Experienced User
What modem/gateway do you have?
Are you using any parental controls/qos/Armor?
