Obiwanfiobi's avatar
Obiwanfiobi
Follower
Apr 06, 2023
Switch for Orbi AX1800
Hi can I use a ethernet switch with this model wifi6 router? I'm not technical-minded so is there any specs I need to tell the electronic store?
1 Reply
  • FURRYe38's avatar
    Yes,
    NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
    Be sure to use good quality CAT6 lan cabling.
