rapshank1882
Jul 29, 2025Tutor
Switching to Community Fibre from BT UK
Hi Does anyone know if the transition from BT FTTP to Community Fibre FTTP is worth it or has anyone on here switched providers? BT is £20 more p/m compared to CF 1Gbps offering which offers...
Jul 29, 2025Guru - Experienced User
Might do a seach on the forums or out on the internet about other CF users and there experiences. I presume you may see varied responces.
For specific ISP configurations, the ISP would know what is required and if you can use exteral routers for there serivces or if ISP equipment maybe required or needed. They will know and should be contacted.
If you don't feel CF is a good fit then up to you to use them or not. If you have working ISP then keep what works for you.
