OHRob
Dec 18, 2025Follower
SXR80 router receives at 2.5 Gbps, transmits under 1.0 Gbps - wireless and ethernet ports.
So I just upgraded to 2.0 Gbps fiber internet service (from 1.0 Gbps). I connect from the provided Nokia ONT to my Orbi router. But when connecting a client -- wired via Orbi's ethernet ports, ...
OHRob
Dec 19, 2025Follower
here is what I have: https://a.co/d/12KQrcI
the marketing is great: touting 6 Gbps wireless speed, but also only 1 G wired ports. So part of my question is answered.
- StephenBDec 19, 2025Guru - Experienced User
So an Orbi 853, not a SXR80.
Note this was launched back in late 2019, so about 6 year old tech. Still a good option, but as you say, no multigig LAN ports.
The newer 873 has multigig LAN ports (as does the less expensive 373).
I'm guessing the wireless speed is what is left?
WiFi specs for the various MacBook Pro models are here:
Can you give more detail on what you have? (processor, year, and and screen size will pin down which spec is relevant for your model).
Note these specs (both for the Orbi and the MacBook) are theoretical physical maximums. Actual throughput will be less. Also, in the case of the Orbi, the spec is the max with multiple clients - not the max for a single client.
