rob_bart
May 19, 2023Aspirant
SYNOLOGY NAS unable to connect to internet through Orbi 960 Satellite when connected directly to it
Orbi Mesh WiFi 6E System - AXE11000 - 3 pack - Black (RBKE963B) Firmware: V6.3.7.10_3.3.3 I have been using Orbis for several years now and recently migrated from a Orbi 5 to a Orbi 6E system w...
CrimpOn
May 19, 2023Guru - Experienced User
rob_bart wrote:
The NAS however, cannot access the internet.
To prevent ambiguity, is the problem that:
- The NAS unit is unable to connect to Sinology resources on the internet, such as to update NAS software, install options, etc. or...
- That it is not possible to access the NAS from the internet?
The direction is rather important.
rob_bart
May 20, 2023Aspirant
As I stated, the NAS cannot connect to the Internet. I am not trying to connect to it FROM the internet.
Nothing on the NAS can connect to Synology services... ie My Synology, Package Center, syncing time, etc.
When I follow the directions on this post (https://www.synoforum.com/threads/nas-connected-to-local-network-but-no-internet.6109/) and SSH into the NAS, it cannot even ping the router.
I feel like the Orbi is absolutely blocking the traffic, but I cannot find where in the Orbi interface to free it up.
All settings that drive the NAS are the same as all other items on my network, ie DHCP enabled, gateways are assigned by the router, etc.
Additionally, been using these steps as well to troubleshoot it: https://kb.synology.com/en-us/DSM/tutorial/Why_cant_I_connect_to_Package_Center
I have a feeling this isn't a Synology issue, but an Orbi issue.
- CrimpOnMay 20, 2023Guru - Experienced User
Thanks for the clarification. Indeed strange.
The obvious place to check is the Security menu under Access Control. Ethernet connected devices are affected by Access Control differently than WiFi devices. For example, when connected to the switch, a PC connected to the same switch will be able to communicate with the NAS even is the NAS is "Blocked" by access control. This is is because switches have internal tables showing which ports lead to specific hardware MAC addresses and packets between the devices never leave the switch. (The Orbi router never sees them, and thus cannot block them.)
Another test is to connect to the NAS from a device that is connected to the primary router on WiFi.
Does the NAS have typical command line tools such as the ability to ping?
- rob_bartMay 20, 2023Aspirant
I can SSH into the NAS. Its some slimmed down variant of Linux.
I have done SSHed into it, and when I ping the router, I get nothing. It times out.
Related to Access Control, I have it turned on, and block all new devices from connecting is enabled. I tried disabling it, but nothing new showed up.
Nothing from the NAS is showing there as blocked (it doesn't show any of the NIC's on the Access Control list at all actually).
In the "allowed devices but not currently connected" list they aren't shown, nor or they in the "blocked devices not currently connected" list.
Under LAN settings, I setup 5 reservations for the 5 NICs on the NAS, and the NAS shows the proper IP address being assigned to them when I plug the cables in.
Whether or not I plug the NAS into the satellite directly, OR the switch, I can access the NAS by machine name.
Right now, the NAS has one network cable, on NIC 2, connected to the second port on the satellite. It was NIC 1 to the first port... just trying something different.
I feel like the only thing I haven't done, is reset the NAS (which doesn't endanger the data, just resets the settings, and I need to reload DSM). Just seems so extreme since I feel like this isn't a Synology issue.
I
It would be useful to eliminate the TRENDnet switch from the environment (temporarily)
With these items connected directly to the Orbi satellite:
- PC
- NAS
Does the NAS appear on the Orbi Attached Devices display with the correct IP address that is assigned to the MAC address?
After connecting to the NAS from the PC (SSH), is it now able to ping anything on the home network? (the Orbi router, for example?) On the internet? (I like ford.com)
- rob_bartMay 21, 2023Aspirant
Thank you for your reply.
I am not certain what putting the PC directly on the satellite will do for the NAS, as they can communicate regardless, and the PC isn't part of the NAS's DNS resolution. However, I have connected both PC and NAS directly to the Orbi Satellite as you requested.
The NAS does not show up in blocked, or connected devices. I even added it to the Approved devices list... each NIC was added to it.
In the Orbi's log, the only reference to the NAS is this:
[DHCP IP: (192.168.1.212)] to MAC address REDACTED_MAC_ADDRESS, Sunday, May 21,2023 07:22:01
There is no other reference to the mac address of the NAS in the log file (I just rebooted the Orbi, so it started the log file anew).
SSHing into the NAS still results in being unable to ping ford.com, or google.com.
Interestingly enough, when I ping, it resolves the IP address for the domain to the router. That does seem peculiar.. I have update the DNS setting of the NIC on the NAS to 8.8.8.8.
Nslookup ford.com returns:
ash-4.4# nslookup
> ford.com
Server: 8.8.8.8
Address: 8.8.8.8#53Non-authoritative answer:
Address: 192.168.1.1
;; Got bad packet: unexpected end of input
38 bytes
8a 6a 81 80 00 01 00 01 00 00 00 00 04 66 6f 72 .j...........for
64 03 63 6f 6d 00 00 1c 00 01 c0 0c 00 1c 00 01 d.com...........
00 00 00 00 00 00 ......Pinging the routers address returns nothing. It fails. It feels so much like the traffic is being black holed from the NAS when the router is receiving it...
And no, I don't have a pihole or anything like that on my network... 🙂
On a lark, I put NIC_2 of the NAS on the DENIED list. That doesn't stop me from accessing the NAS.
Remember, we put attached the PC and the NAS directly to the satellite. I am really having a hard time understanding out the Orbi's networking works...
In the Orbis log, there is nothing related to denying anything for NIC_2, just giving it its IP address (which, yes, it still does even though its on the denied list).
With the DNS set to 8.8.8.8, I did the NSLOOKUP again:
ash-4.4# nslookup ford.com
Server: 8.8.8.8
38 bytes
71 77 81 80 00 01 00 01 00 00 00 00 04 66 6f 72 qw...........for
00 00 00 00 00 00 ......- CrimpOnMay 21, 2023Guru - Experienced User
(not confident that my suggestions have been very helpful so far.....)
I notice in the Synology Installation manual for the 1522+, they show one Ethernet cable connected to port 1 of the NAS. (The product accepts up to five Ethernet connections, so there seems to be no reason why port 1 would be significant. Maybe multiple ports are not active until after the operating system is fully configured?)
What I would expect is that when port 1 of the NAS is connected to any of the LAN ports on the RBSE960 satellite, that within a few minutes the router Attached Devices display should show the MAC address of that port as "Connected" (to the satellite) and assigned the IP address that was defined in the LAN setup table. (Orbi status does not update instantly.)
The satellite's web page should also show the NAS MAC interface as connected with the correct IP. (If you have defined a "name" for the NAS interface, the satellite may show that as "unknown", but that's a different issue.)
My reason for turning off Access Control and removing that sophisticated switch is to reduce the number of potential variables.
Once the NAS appears in Attached Devices, then a computer that is not connected to that satellite should be able to ping the NAS.
