Starky-50
Jun 01, 2022Aspirant
Take a RBS850 apart, how to do that
I want a manual to remove the cover from my RBS850. One of the mounting points on the bottom has come loose. Does anyone have a description of how to take it apart.
That will do.
thnx.
Look either at the back for front down under where the front white cover meets the front LED, There is a tab on the side on the back of the white cover. Press this towards the cover itself. Then I believe you gently push upwards and the cover should come off.
There are pictures of the case in the FCC filing for the 850:
https://fccid.io/PY319200453/Internal-Photos/Internal-Photos-rev-Part-1-4433134
- Starky-50Aspirant
That will do.
thnx.
