pco614
Mar 11, 2026Tutor
The RBS will not go to solid white
I'm having the same problem, only to add frustration, the RBS will not go to solid white, after reset connected to computer via ethernet with RBR turned off, it flashes white for a while, and then gl...
CrimpOn
Mar 11, 2026Guru - Experienced User
Page 11 of the User Manual does not show the satellite ever showing solid white.
https://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdf
Magenta (i.e. "pink") means that it did not sync with the router.
