pco614
Mar 11, 2026Tutor
The RBS will not go to solid white
I'm having the same problem, only to add frustration, the RBS will not go to solid white, after reset connected to computer via ethernet with RBR turned off, it flashes white for a while, and then gl...
- Mar 13, 2026
Hi All, I just wanted to say that I fixed the problem. I went back to the most recent previous firmware version on the router, and although the satellites were out of sync, they were recognized. I matched the firmware to the router version and all is fine. I can now do the new update ( doing the satellites first this time...) Thanks again.
pco614
Mar 13, 2026Tutor
