920cody
Jun 04, 2024Aspirant
Took a firmware update on RBR752 and now cannot access router!
I signed into my Orbi app on my phone and saw an update was available for a remote Orbi network I have at my Winter home. So, I updated. Now, when I try to access the router through the app, I'm told...
920cody
Jun 05, 2024Aspirant
How do I revert back to previous firmware version?
Jun 05, 2024Guru - Experienced User
Same way you update FW manually:
RBS first, RBR lastly. Factory reset then setup from scratch.
- 920codyJun 05, 2024Aspirant
I wasn't sure if it would complain about trying to install an older version. I know some won't allow lower version numbers. Good to know. Thanks!
- FURRYe38Jun 05, 2024Guru - Experienced User
Yes it may show you information about that. It's ok.
Just don't downgrade to v4. v.21 is good though.
