kevin009
Apr 01, 2022Star
Tracking/logging orbi satellite connection outages
I have an Orbi AX6000 kit (RBK852, for some reason, this model isn't available in the model dropdown) and the connection to my satellite keeps dropping randomly. The only way I can tell is because I h...
- Apr 22, 2022
kevin009 wrote:
I'm not sure what else I could connect directly to the satellite to test if it's the satellite or not. Maybe another camera that has it's own power source. I'll have to do some digging.
At 2 seconds, missing 90 in a row comes to three minutes of no response. The satellite itself appears to be responding, but devices 'wired' to the satellite have these gaps. Would be useful to know if the cameras experience the lack of response at the same time.
It is getting rare for consumers to have devices with Ethernet ports, which complicates troubleshooting this sort of thing. Does this PoE switch have an IP address?
There have been some posts on the forum regarding 850-series satellite problems. As I do not have an 850, I confess to not paying a lot of attention to the specifics. It might be worth some time skimming the AX forum to see if any posts seem to relate to your situation.
It also might be useful to manually update the firmware to the most recent version on the support web site:
https://www.netgear.com/support/product/rbr850.aspx#download
Apr 01, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
kevin009
Apr 10, 2022Star
- V4.6.3.16_2.0.51
- It's a Shaw Bluecurve CGM4141SHW. Haven't had any issues with the ISP. Our internet connection is solid, it just seems to be the Orbi satellite.
- Medium bungalow, about 800 Sq ft.
What is the distance between the router and satellite(s)?
- 25 feet in a detached garage.
- Currently I'm using 2.4GHz Channel: 01 and 5GHz Channel: 36
- Not a lot, but there's a couple.
