kevin009
Apr 01, 2022Star
Tracking/logging orbi satellite connection outages
I have an Orbi AX6000 kit (RBK852, for some reason, this model isn't available in the model dropdown) and the connection to my satellite keeps dropping randomly. The only way I can tell is because I h...
- Apr 22, 2022
kevin009 wrote:
I'm not sure what else I could connect directly to the satellite to test if it's the satellite or not. Maybe another camera that has it's own power source. I'll have to do some digging.
At 2 seconds, missing 90 in a row comes to three minutes of no response. The satellite itself appears to be responding, but devices 'wired' to the satellite have these gaps. Would be useful to know if the cameras experience the lack of response at the same time.
It is getting rare for consumers to have devices with Ethernet ports, which complicates troubleshooting this sort of thing. Does this PoE switch have an IP address?
There have been some posts on the forum regarding 850-series satellite problems. As I do not have an 850, I confess to not paying a lot of attention to the specifics. It might be worth some time skimming the AX forum to see if any posts seem to relate to your situation.
It also might be useful to manually update the firmware to the most recent version on the support web site:
https://www.netgear.com/support/product/rbr850.aspx#download
CrimpOn
Apr 10, 2022Guru - Experienced User
kevin009 wrote:
I know the Orbi have very little when it comes to tools/troubleshooting/options, but I was hoping that Netgear might have a tool that could help me get an idea of how often, how long, etc my satellite is going down, so I could hopefully troubleshoot it. Any thoughts?
If there are tools built into the Orbi to diagnose satellite connection issues, I am not aware of them. There is a debug option on many Orbi products which creates a file of information that can be explored once the file is saved to the user's computer. Unfortunately, I am not aware of any documentation explaining what is in this log file.
The tool most people use to diagnose connection problems is to continuously perform ICMP ('ping') requests and record when they fail. My "go to" ping tracker is PingInfoView from Nirsoft. (free at https://www.nirsoft.net/utils/multiple_ping_tool.html ) That is assuming, of course, that the security cameras respond to ICMP requests. Most devices on my network do respond.
I use the Advanced option to write a line into a log file every time a device does not respond.
PingInfoView would establish a few things:
- Confirm (or refute) that the link between router and devices is failing (perhaps the link between router and satellite if the satellite IP is one of the devices being pinged).
- Create a record of time and duration of the interruptions.
I would not be surprised to find that security cameras do not respond to every ping. If there is a long string of missed responses, say every 2 seconds for over several minutes, that would be evidence of a network issue.
kevin009
Apr 12, 2022Star
Ok, that is a pretty handy tool. I set it up yesterday to ping all my cameras (they do respond to pings) and the satellite and there were a LOT of failures for everything throughout the night. There were a couple of instances where all of the cameras didn't respond, and there were some instances where everything didn't respond (for about 4 minutes too, so these aren't small outages). So the fact that I'm seeing the satellite not respond tells me (unless I'm misinterpreting this) that there's an issue with the connection between my main orbi and the satellite, but I'm not sure what to do with this information. If it's defective, I think I'm past my warranty period.
I just thought of something. I should have also added my main orbi unit to the list, just to verify that the outage isn't caused by my main router. I'm going to do that now.
