MKnichel's avatar
MKnichel
Trouble connecting Orbi Satellite.
I have an Orbi RBR850 and I want to connect a satellite (RBS350) to is but it is not working.  I go through the process and the LED turns solid blue for a while then after a few minutes starts blinki...
  • MKnichel's avatar
    MKnichel
    Nov 04, 2025
    Thanks, but I find conflicting info regarding the compatibility...  I got it figured out.  Found a 750 in our storage and it is compatible with the 350s...
