Peteri45
Jan 08, 2023Aspirant
Uk Virgin Super hub 4 and Orbi rbre960 + 3 satellites
All working now but now, but should i switch of the wifi on virgin SH4 and put into Modem mode as today i had to factory reset the Virgin suoerhub 4 as internet was intermittent. I now have the vir...
- Jan 08, 2023
The IP address you use there is what the RBR gets from the modem. So set up a IP address reservation for the RBR on the modem, then input this same IP address into the modems DMZ.
Jan 08, 2023Guru - Experienced User
IF your wanting to sue the Orbi as the main router and for everything, I recommend bridging the Superhub and disabling it's wifi. IF the SuperHub can't be fully bridged then disable it's wifi and use the hubs DMZ or IP pass thru for the RBR.
Might as the ISP if the RBR can replace the Superhub unit.
DNS can be set to anything on the RBR, Auto detect or use custom DNS of your choice.
- Peteri45Jan 08, 2023Aspirant
Hi Thanks for the quick response, the SH4 does not appear to have a bridge mode so I can choose modem mode, There is a DMZ option but I will have to choose an address, what is the answer to that pls
thanks
DMZ address192.168.0.
