Peteri45
Jan 08, 2023Aspirant
Uk Virgin Super hub 4 and Orbi rbre960 + 3 satellites
All working now but now, but should i switch of the wifi on virgin SH4 and put into Modem mode as today i had to factory reset the Virgin suoerhub 4 as internet was intermittent. I now have the vir...
- Jan 08, 2023
The IP address you use there is what the RBR gets from the modem. So set up a IP address reservation for the RBR on the modem, then input this same IP address into the modems DMZ.
Peteri45
Hi Thanks for the quick response, the SH4 does not appear to have a bridge mode so I can choose modem mode, There is a DMZ option but I will have to choose an address, what is the answer to that pls
thanks
DMZ address192.168.0.
Jan 08, 2023Guru - Experienced User
