hTep's avatar
hTep
Guide
Oct 26, 2025
Unable to access orbi web interface through reverse proxy
Hello,
I set up a reverse proxy on my NAS that access multiple services. All are working great.
I would like to access the orbi web management interface remotely through my nas (reverse proxy).
So I set origine and destination on 430 port with hostname orbi.mydomain.me to 10.0.0.1 (orbi lan IP).
My Orbi 750 is set on router mode, not AP mode.
What do I miss?
Thanks
  • CrimpOn's avatar
    CrimpOn
    More detail about how it doesn't work?
    • no response at all?
    • refuses to connect?
    • error message?
  • CrimpOn's avatar
    CrimpOn
    Confess I have never set up a reverse proxy. (or used any sort of proxy)
    • What are the connections that work? (any of them web sites?)
    • Can you publish the configurations that work?
  • CrimpOn's avatar
    CrimpOn
    Although I have forwarded many Ports through my Netgear router to devices on the LAN, I am not confident that port 430 (https) can be.
    Have you tried using port 80?
    • StephenB's avatar
      CrimpOn wrote:
      port 430 (https)
      HTTPS is port 443, not 430.
      430 is assigned to a protocol called utmpsd.  No idea what that service is, the IANA port registry doesn't say.
      hTep
      Do any of the other services use SSL/TLS?
      • hTep's avatar
        hTep
        Guide
        My mistake team, error while typing.
        port is 443 of course
        still doesn’t work:)
    • hTep's avatar
      hTep
      Guide
      Yep, tried with 80 and 430... same...
