itsAjayV
Oct 01, 2024Tutor
Unable to add two additional satellites (RBS750) to existing RBR750 setup
Hi all, Note: This is my first time posting on this community so pardon me if I make errors or ask a question that's already been asked. I did my due diligence and reviewed the community and sear...
- Oct 01, 2024
Best way to hopefully get the incoming RBS to connect to existing system, would be to setup the 2nd RBR and RBS, off line from the current system and update the RBR and RBS so that they are on same level of FW as the existing system. No need to connect the RBR to the ISP modem. Leave the current system running. I'd turn OFF the existing RBS to better help get incoming RBS connected at a later point.
Have the RBR and RBS v.31 FW files already downloaded to a wired PC.
With the 2nd system, setup the system using a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Bring the 2nd set of RBS to same room or near the 2nd RBR.
Allow the setup wizard to manually setup the system. Can follow this PDF process:
Skip pass the factory reset point the the PDF and where your waiting for the setup wizard web page to appear in the web browser. Then continue the process from there.
After the 2nd RBR and RBSs are setup and connected to each other and your at the home page for the RBR, manually update the RBS to v.31 FW, then update the 2nd RBR lastly to v.31. This PDF process gives details on how to manually update an Orbi system:
Once the 2nd Orbi set is fully updated. I believe you should be able to power OFF the 2nd RBR. I'd power off one of the 2nd set RBS leaving one ON. While the one is ON, the RBS will begin to blink or turn PINK in front. Log into the 1st RBRs web page with a web browser and use the 1st RBR Add Satellite feature to add the 1st coming RBS to the existing system. Hopefully should sync and the front RBS LED should turn BLUE. After 3 minutes, turn OFF the 1st incoming RBS and turn ON the 2nd RBS. Give a few minutes then run thru the RBRs Add Satellite feature again to get the 2nd incoming RBS connected. Hopefully this connects as well.
If both incoming RBS syncs fully to the existing RBR, then you can power them off and then go place them in there remote locations then power them all ON one at a time.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
itsAjayV
Oct 01, 2024Tutor
FURRYe38 CrimpOn , you both rock! Truly.
Not sure if I'm responding/replying correctly but thanks to both of your help, I was able to successfully get both the addition two satellites up and running!
FURRYe38 Absolutely loved and appreciated your detailed, thorough and step-by-step instructions.
CrimpOn You nailed it - firmware update was the issue. Loved the idea of testing out the secondary unit to rule out if it's faulty or not.
Taking both your expertise and inputs, here's what I essentially did:
- Unplugged the original/primary router and setup the secondary router and satellite as a "new Orbi system."
- Thanks to FURRYe38 's detailed instructions, I knew exactly what to unplug and leave on. Thereafter, used the admin console on my computer to manually do a firmware update on both satellites.
- Ensured they both connected one at a time and together.
- Unplugged the secondary router and synced the satellites one by one as directed by FURRYe38 .
- Unplugged them both, placed them where I wanted them. Now all four satellites are up and running with good WiFi strength and coverage, all running the same firmware.
You two rock! It's no surprise why you two are ranked as the highest contributors. Thank you both again!
PS: I have an Arlo Floodlight Camera-related issue. Are either of you experts in that as well? Figured it's also a Netgear brand, so thought I'd ask. Thanks in advance.
Cheers.
CrimpOn
Oct 01, 2024Guru - Experienced User
No experience with Arlo, however................... Most cameras get connected to WiFi by having the smartphone app create a QR code containing the WiFi credentials, and then pointing the camera at the QR code.
What sort of issue do you have?
- itsAjayVOct 03, 2024Tutor
CrimpOn It's the Arlo Floodlight 3. There's a pinkish/reddish hint on the video. I've tried resetting it, removing the battery, waiting a few seconds and re-installing it, removed device and added it again but none of it helped. It seems like an hardware issue. Online forums say it's the IR sensor? Curious if you have any insight into this. Thanks in advance.
- CrimpOnOct 03, 2024Guru - Experienced User
Hard to imagine that a sensor of any kind would create a tint on video recording. Some of the IR "illuminators" used to produce pictures in near darkness have a reddish appearance when viewed directly, but when the IR LEDs are on, my (not Arlo) cameras produce a black & white picture.
Is this tint on color (daytime) recordings or night recordings?
My cameras have an option to disable the IR LEDs, which would provide a quick test of that theory.
