thunder929
Sep 27, 2022Aspirant
Unable to login to RBS350 satellite
I have been unable to log into my satellite. I tried using the router user and pass and the default user pass of admin/password. The route is showed as synced as well. Is there another password ...
thunder929
For anyone else that runs into this.
I factory reset just the satellites. Once this was done it accepted the default user/pass of admin/password.
Sep 27, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
