PHawks's avatar
PHawks
Unknown device Orbi AX4200
Hi, I have this weird ‘Xerox’ thing showing up. What is it and how do I get rid of it?
  • If it's working and your not bothered by it, then up to you.
    • PHawks's avatar
      PHawks
      Nope, I have nothing like that. It just popped up out of nowhere...
  • FURRYe38's avatar
    Can you provide a screen capture of this?
    Please use the Choose File to attached the screen capture file to your post.
    • PHawks's avatar
      PHawks
      Sure...
      • FURRYe38's avatar
        Ah the phanton RBS. You'll need to factory reset the RBR and RBS and setup from scratch. Use a wired PC and web browser to do this.
