Ragutis's avatar
Ragutis
Tutor
Feb 22, 2023
Unknown new 'satellite' shown
Hi
I have the RBK853 WiFi 6 Mesh which has the 2 satellite, RBS850. Usually when I look at attached devices in the Orbi software I see the 2 RBS850 under the 'Connected Satellites' section and then a whole list of devices under the 'Connected Devices' section.
Today under the 'Connected Satellites' section there appears to be a 3rd satellite which is shown as 'XEROX CORPORATION' in the device name. Backhaul status is shown as 'Disconnected' and there is a button given to remove it.
I do not, and never have had, a third satellite. It isn't my printer which is not Xerox and is shown in the 'Connected Devices' section where it should be anyway.
Does anybody know why this could be showing as a satellite?
Firmware v4.6.14.3_2.3.12
Windows 10
Thanks
  • Other posters historically have posted about the same issue, FR was the permanent resolution.
  • FURRYe38's avatar
    Factory reset the RBR and RBS and setup from scratch.
    Be sure FW is same on all RBS as what's loaded on the RBR.
    • Ragutis's avatar
      Ragutis
      Tutor
      Thanks for replying.
      Can you tell me why that is the solution? Is it not ok to just delete the extra 'satellite'?
      • FURRYe38's avatar
