wap1
Aug 11, 2021Aspirant
Unknown wlan0 devices on 2.4 ghz Orbi network
On my RBR750 router with two wireless mesh satellites (Orbi RBK752 system), I occasionally see two devices connected to the 2.4 ghz wireless network, and they are both labeled “wlan0”. What are these? Are they associated with the satellites? All other devices in the house are accounted for in the devices list, but I don’t know what the wlan0’s are.
Thanks in advance for the help.
- Solution was found on duplicate posting in another thread https://community.netgear.com/t5/Orbi/Unknown-wlan0-devices-on-2-4-ghz-Orbi-network/m-p/2126989/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtTOEdFMTJLUEFLWjZLfDIxMjY5ODl8U1VCU0NSSVBUSU9OU3xoSw#M124360
Thanks the the help!
There a screen capture picture of this?
Where are you seeing this "wlan0" at? On the status page on the RBR, RBS or Orbi app?
- wap1AspirantSolution was found on duplicate posting in another thread https://community.netgear.com/t5/Orbi/Unknown-wlan0-devices-on-2-4-ghz-Orbi-network/m-p/2126989/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtTOEdFMTJLUEFLWjZLfDIxMjY5ODl8U1VCU0NSSVBUSU9OU3xoSw#M124360
Thanks the the help!- FURRYe38Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
