cv123's avatar
cv123
Guide
Aug 21, 2022
Update firmware from 4.6.8.2 rbs850
I cant get to the interface to update the firmware. I've tried to reset but it hasn't worked.
Any suggestions?
  • cv123's avatar
    cv123
    Aug 21, 2022
    The RBR was ok. It's the RBS.
    I has to power down the RBR, connect to the RBS with ethernet and reset. I was able to pull it up from 192.168.1.250.
    From there I could do the firmware update, but once up and running, I still can't connect to the RBS from the web for future updates.
    Is that something new?
  • FURRYe38's avatar
    So connecting 1 ethernet connected PC to the back of the RBR and pressing the reset button for 15 seconds then release with the RBR disconnected from the ISP modem/ONT then using a web browser to navigate to 192.168.1.1 after the front LED stars to pulsate WHITE doesn't pull up the setup wizard on the RBR? Try a different broswser? MS Edge, Firefox or Opera?
    • cv123's avatar
      cv123
      Guide
      • FURRYe38's avatar
        Ok sorry about that, got the RBS mixed up.
        Does the RBS entry appear in the RBRs web page as a disconnected RBS? IF so, Select Remove button there and reboot the RBR. then try the manual sync after the RBR is back to ready by pressing the sync button on the RBS first then the RBR. I would do this in same room as the RBR with the RBS.
        Be sure all future updates, the RBS gets updated FIRST, then the RBR lastly.
