jogovaer
Aug 15, 2022Initiate
Update RBR850 gives “firmware check error
When I want to update my router via the orbi app I always get the message that there is a problem checking firmware update. How can I solve this? Beside this I find it rare that my satellites have ...
- Aug 15, 2022Firmware version: V4.6.3.16
I did not try to update via the browser. I will try to do this
Thanks for the advice
Aug 15, 2022Guru - Experienced User
jogovaer wrote:
When I want to update my router via the orbi app I always get the message that there is a problem checking firmware update. How can I solve this?---Have you tried updating through the browser?
Or manually?
What firmware version are you on?
Beside this I find it rare that my satellites have never a device connected even when they’re a lot closer than the base station. Is this normal?----Depends. Its the device itself (phone/tablet/etc) that actually does the roaming. But the app doesn't always do the best job of showing what its connected to. Have you logged in through the browser and compared it online?
jogovaer
