jhaller54's avatar
jhaller54
Follower
Nov 13, 2025
Use both 6E router/satellite and 6 router/satellite?
I have the 6 and 6E systems. Given the speeds available on these routers and satellites, I do not see the advantage in moving to the 7 system.
I have a very large home. The 6E system is about a year old but unused. I have the router and two satellites.
I am getting fiber internet soon. I would like to use the 6E system as the main router. Can I also use the 6 system, and, if so, how do I set this up. There are a couple of places that the current 6 system does not reach so rather than investing in additional 6E satellites I would like to use the 6 router and satellite.
Any thoughts?
  • CrimpOn's avatar
    CrimpOn
    Netgear's documentation on Orbi product compatibility shows that the WiFi6E system is not compatible with any WiFi6 satellites.  What you can do is connect the WiFi6 router WAN port to one of the WiFi6E system LAN ports (either the router or one of the satellites) and run it as an independent WiFi system.  It can use the same WiFi credentials as the 6E system, but will be a separate system.  i.e. mobile WiFi devices will not roam seamlessly between the two systems.
    The awkward part is that Ethernet connection.  If a short Ethernet cable is used, then there will be two WiFi access points very close to each other, which does not expand the coverage area.
    jhaller54 wrote:
    Any thoughts?
    Bummer that the 6E system will be "out of warranty" before it even gets installed.
