CincyNeb's avatar
CincyNeb
Used Orbi 860 Connection
My friend gave me his Orbi 860 system since his internet company gave him one to work with.  I tried to factory re-set the router and it keeps showing up with their old network name.,
How do I set this up for use in my home?  Do I need to get his password and go into the app or is there a better way?
  • FURRYe38's avatar
    Be sure to press the reset button for 15 seconds, then release.
  • I did.  So, I'm assuming that the paper clip reset wasn't completed correctly?  I'll retry.
    • StephenB's avatar
      Power on the Orbi and let it fully boot.  Then hold down the reset button until the power LED blinks amber.
      Netgear has a video here:
      • https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
  • StephenB's avatar
    You did this with the paper-clip reset?
    Does the network name match the one printed on the router label?
    If the reset was successful, it would have reset the admin password back to password.
