Rivendell's avatar
Rivendell
Follower
Jun 15, 2021
Using Orbi wifi 6 AX4200 with the new T-Mobile Home Interne gateway chimney
I am trying to connect my ORBI AX4200 to the new T-Moble Home Internet Gateway 5G chimney.  I have tried changing the ORBI to an access point only but it keeps rebooting itself several times a day and if you are familiar with the ORBI, the reboot process takes about ten minutes and during this time I have no internet access.  I was hoping there were some other settings I need to use to make this work and that there was someone else that has done it successfully and could advise plesae.
1 Reply
  • FURRYe38's avatar
    Should not take 10 minutes for the system to reboot. If it is, there maybe a problem with the Orbi system and needs to be replaced.
    Check the LAN cable in between the modem and RBR. CAT6 is recommended.
    Be sure to use the Yellow LAN port for either router or AP mode to the ISP modem.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
