stephenramsden
Mar 15, 2024Aspirant
Using same SSID on replacement RBR850 router would not work.
I have two complete Orbi systems with satellites, one at each home here in Georgia. They have worked very well and I’m very happy with them. , The 4 year old RBE850 ORBI 6 started dropping its Wi-Fi ...
- Mar 15, 2024
what I'd try?
Go through and shut off as many of your wifi devices as possible. Then setup the orbi with the same ssid/password. Start slowly turning devices back on to see if they work.
Reason I say this is for about a year, I had an issue with an orbi on bootup if my firetv box was on. If I unplugged the firetv and booted up everything and then turned on the firetv, it was fine. But if the firetv was on first, it wouldn't bootup properly. That was a challenge to figure out that it was something with the firetv causing issues and not the router.
I'm not sure if it was flooding the router with requests on bootup or what the issue turned out to be because I got tired of messing with it and threw it out.
Just curious if thats the issue. And if switching the SSID to a different one is just making it so whatever device is causing the issue isn't flooding the router on bootup.
CrimpOn
Mar 15, 2024Guru - Experienced User
I agree entirely that using the same WiFi credentials is "the way to go." I have kept the same WiFi credentials for over 20 years for just the reasons you indicated:
- Allows all WiFi devices to connect to the new system without reconfiguring, and
- If I decide to "go back" to the previous system, all devices will connect to it as well.
There have been posts on the forum previously describing this same issue (cannot set up new system with existing SSID/password).and I do not recall them being resolved either.
In a technical sense, it is hard to imagine how configuring the WiFi credentials could appear different (to devices) than a system restart (either deliberately, power outage, or firmware update. There are all sorts of administrative actions that cause the Orbi WiFi radio system to restart.
All those devices are sitting there waiting... "sure wish there was a WiFi network that I recognize. Been sitting here for quite a while with no network to use. Oh, look. Here's one. Associate me NOW!"
I'd agree that reusing them is the best bet. I'm going on over a decade of the same SSID. the only issue I ever had was with the one device causing problems. Once that was removed, zero issues.
