flyingdutchgeek
Jul 30, 2025Tutor
Using Wired Backhaul, the internet is slow and jittering
I have similar problem with RBSE960. Using Wired Backhaul, the internet is slow and jittering. On the Orbi Router portal is says Backhaul status = Good When i unplug the cable and Backhaul via 5 ...
Jul 30, 2025Guru - Experienced User
Just wondering had you factory reset the system after v.15 was loaded to check this?
Are RBS ethernet connected directly behind the RBR or is there a LAN switch in the mix?
Only knowns issues are with IPv6 on v.15 FW is not working. Otherwise is good FW.
I had my 960 series online for 30 days, RBS wireless connected. Saw no issues.
Share your Orbi 350, 750, 850 or 960 series system UpTime | NETGEAR Communities
Had my 850 online for 30 plus days earlier this year, those RBS were Ethernet connected, same FW. No issues.
- flyingdutchgeekJul 31, 2025Tutor
Yes, reset multiple times.
RBS is connected direct to RBR with CAT6
IP6 is disabled
When I connect RBS wireless there is no issue, so problem is isolated to wired backhaul.
- FURRYe38Jul 31, 2025Guru - Experienced User
How are the RBS connected to the RBR when ETH? Directly behind the RBR or is there any LAN switches in between?
- Retired_MemberAug 02, 2025
After doing the factory reset, did you restore your configuration, or did you setup from scratch?
