flyingdutchgeek
Jul 30, 2025Tutor
Using Wired Backhaul, the internet is slow and jittering
I have similar problem with RBSE960. Using Wired Backhaul, the internet is slow and jittering. On the Orbi Router portal is says Backhaul status = Good When i unplug the cable and Backhaul via 5 ...
Jul 30, 2025Guru - Experienced User
Just wondering had you factory reset the system after v.15 was loaded to check this?
Are RBS ethernet connected directly behind the RBR or is there a LAN switch in the mix?
Only knowns issues are with IPv6 on v.15 FW is not working. Otherwise is good FW.
I had my 960 series online for 30 days, RBS wireless connected. Saw no issues.
Share your Orbi 350, 750, 850 or 960 series system UpTime | NETGEAR Communities
Had my 850 online for 30 plus days earlier this year, those RBS were Ethernet connected, same FW. No issues.
flyingdutchgeek
Jul 31, 2025Tutor
Yes, reset multiple times.
RBS is connected direct to RBR with CAT6
IP6 is disabled
When I connect RBS wireless there is no issue, so problem is isolated to wired backhaul.
- FURRYe38Jul 31, 2025Guru - Experienced User
How are the RBS connected to the RBR when ETH? Directly behind the RBR or is there any LAN switches in between?
- Retired_MemberAug 02, 2025
After doing the factory reset, did you restore your configuration, or did you setup from scratch?
