flyingdutchgeek
Jul 30, 2025Tutor
Using Wired Backhaul, the internet is slow and jittering
I have similar problem with RBSE960. Using Wired Backhaul, the internet is slow and jittering. On the Orbi Router portal is says Backhaul status = Good When i unplug the cable and Backhaul via 5 ...
flyingdutchgeek
Jul 31, 2025Tutor
Yes, reset multiple times.
RBS is connected direct to RBR with CAT6
IP6 is disabled
When I connect RBS wireless there is no issue, so problem is isolated to wired backhaul.
Jul 31, 2025Guru - Experienced User
How are the RBS connected to the RBR when ETH? Directly behind the RBR or is there any LAN switches in between?
