flyingdutchgeek
Jul 30, 2025Tutor
Using Wired Backhaul, the internet is slow and jittering
I have similar problem with RBSE960. Using Wired Backhaul, the internet is slow and jittering. On the Orbi Router portal is says Backhaul status = Good When i unplug the cable and Backhaul via 5 ...
flyingdutchgeek
Jul 31, 2025Tutor
Yes, reset multiple times.
RBS is connected direct to RBR with CAT6
IP6 is disabled
When I connect RBS wireless there is no issue, so problem is isolated to wired backhaul.
liamscor
Aug 02, 2025Luminary
After doing the factory reset, did you restore your configuration, or did you setup from scratch?
