flyingdutchgeek
Jul 30, 2025Tutor
Using Wired Backhaul, the internet is slow and jittering
I have similar problem with RBSE960. Using Wired Backhaul, the internet is slow and jittering. On the Orbi Router portal is says Backhaul status = Good When i unplug the cable and Backhaul via 5 ...
flyingdutchgeek
Aug 02, 2025Tutor
The factory reset was performed on the RBS, and after a sync, it was configured again. I did not restore anything myself.
- FURRYe38Aug 02, 2025Guru - Experienced User
How are the RBS connected to the RBR when ETH? Directly behind the RBR or is there any LAN switches in between?
- flyingdutchgeekAug 03, 2025Tutor
Direct
- FURRYe38Aug 03, 2025Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰What CAT# LAN cable is being used?
- Retired_MemberAug 06, 2025
You need to perform a factory set from the RBR web gui, and then setup from scratch again, without loading any backup file.
