flyingdutchgeek
Jul 30, 2025Tutor
Using Wired Backhaul, the internet is slow and jittering
 I have similar problem with RBSE960. Using Wired Backhaul, the internet is slow and jittering. On the Orbi Router portal is says Backhaul status = Good     When i unplug the cable and Backhaul via 5 ...
flyingdutchgeek
Aug 02, 2025Tutor
The factory reset was performed on the RBS, and after a sync, it was configured again. I did not restore anything myself.
Aug 02, 2025Guru - Experienced User
How are the RBS connected to the RBR when ETH? Directly behind the RBR or is there any LAN switches in between?
- flyingdutchgeekAug 03, 2025TutorDirect - FURRYe38Aug 03, 2025Guru - Experienced UserWhat is the size of your home? Sq Ft?
 What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
 https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰What CAT# LAN cable is being used? - flyingdutchgeekAug 05, 2025TutorRBR and RBS are about 18 meter apart, and there is one floor in between - wood and brick house. Not sure how relevatn this is, as the RBR is connected via CAT6 UTP to the RBS. Let me be clear: - with V7.2.6.31 the RBR works great with wired backhaul
- with V7.2.7.15 the RBR does not work with wired backhaul - connnection indicates good, but MBPs goes down to 0 after one second.
