flyingdutchgeek
Jul 30, 2025Tutor
Using Wired Backhaul, the internet is slow and jittering
I have similar problem with RBSE960. Using Wired Backhaul, the internet is slow and jittering. On the Orbi Router portal is says Backhaul status = Good When i unplug the cable and Backhaul via 5 ...
flyingdutchgeek
Aug 02, 2025Tutor
The factory reset was performed on the RBS, and after a sync, it was configured again. I did not restore anything myself.
Retired_Member
Aug 06, 2025You need to perform a factory set from the RBR web gui, and then setup from scratch again, without loading any backup file.
