grizzlybare
Jul 11, 2024Aspirant
Using WIRELESS ORBI RBS850 with RBR750
I purchase an RBR750 and two RBS750. Everything worked fine. I needed more wireless coverage thinking I would switch out the RBR750 for an RBR850 with an RBS850. Things didn’t work together. Now I have both routers and three satellites (2-RBS750 and 1-RBS850. I know I can only run one router and according to NETGEAR the three satellites should work with either router, but no go. After resetting and syncing the only thing I can connect in the 750 router and the two 750 sats. The 850 sat just blink white.
Be sure FW on the RBS750/850 is same version of FW as the RBR750/850.
Try syncing the RBS850 to the RBR750 with all other RBS turned OFF.
- grizzlybareAspirant
I’m new at this. How do you check firmware version and how to update?
Any progress on this?
