Intensified's avatar
Intensified
Uuuuummmm what? Amazon plug shows up as Satellite.
So, I have something called AmazonPlug5JHQ as a satallite.  I am sure it is an Amazon smart plug, and it wouldn't be unreasonable for me to have missed setting up one of them when I changed my SSID, but any idea why it is showing up as a Satallite?  I don't think it is hurting anything, just curioius.
  • FURRYe38's avatar
    Is this on the RBK50 or Orbi AX system?
    Is this in the Orbi app and RBRs web page as well?
    Can you attached the picture file using Choose FIle button on your post?
