Rasta-NY
Sep 14, 2021Follower
V4.6.3.16 firmware
Anyone familiar that there's a new firmware RBK750 V4.6.3.16 firmware
RBR750
out for RBR750S
- ValidusLuminary
There are Orbi Beta Firmware v4.6.3.16 (RBR750) and Orbi Beta Firmware v4.6.3.16 (RBR850/RBS850)
As they are still under Beta, you would have to request access into the Beta testing group to get them, if you desire to use it right now.
Contact "DarrenM" via Private Message to request Beta access and your reason why:
https://community.netgear.com/t5/user/viewprofilepage/user-id/2257
It's update:
- Speedtest Discrepancy
- Throughput/incorrect speedtest results
- Stability issues
Also tends to help those (including myself - using the RBR850) with DNS Errors, that the previous version helped but didn't fully resolve.
- tucsonticoVirtuoso
I have been in email conversations with support regarding apparent bugs and degrading WiFi speeds over time. This morning I noticed Netgear pushed that firmware update to me without my consent! If it truly is a beta version, I'm even more upset. Haven't had any chance to test speeds, stability, etc.. Will report my experince when able.
Keep us posted.
Try a FULL on power OFF of the RBR and RBS and ISP modem for 2 minutes then back ON.
- InitialGGuide
Can confirm that my router and satellite just auto updated this evening as follows:
Firmware Version
V4.6.3.16_2.0.51now to see how it behaves ...
