snoyogi2's avatar
Jul 15, 2024
V7.2.6.31_5.0.24 changes guest network password from none to default Password123
After upgrading, a default password was assigned to my guest network with
WPA2-PSK [AES], password <Password123>.
If I selected Other Networks -> Other... then selected security None, I could still join without a password.
I was able to resolve the problem by reconfiguring guest to have no password. I hope this does not happen again.
  • FURRYe38's avatar
    Password123 is has always been the default password for Orbi Guest networks. Been like that for a while now.
    • snoyogi2's avatar
      snoyogi2
      Tutor
      When I reboot the router, it adds a password with WPA2 security when there was none before. It did not exhibit this behavior before upgrade. I have subsequently added a password to my guest network.
      • FURRYe38's avatar
        Has a factory reset and setup from scratch been performed since last update?
  • FURRYe38's avatar
    Any progress on this?
