Timtech's avatar
Timtech
Apprentice
Apr 06, 2025
v7.2.7.15 Firmware on RBR 850. Can someone run GRC.com Shields Up
Can you please run Grc.com’s shields up and let me know if you can get full stealth?
https://www.grc.com/x/ne.dll?bh0bkyd2
This is the best I can get.
I am running Armor.  Is that causing ports to appear closed?
  • Odd.  I tested today and it’s all stealth.
    But unsolicited packets failed.  A complete 180 from before.
  • FURRYe38's avatar
    Is this with nothing else connected to the RBR850 accept for one wired PC and Armor diabled with a single broswer opening to only the GRC web page?
    • Timtech's avatar
      Timtech
      Apprentice
      It’s with 50 or so items on the guest network.. and 10 or so on the primary WiFi.
      I also have two RBS 850s connected.
      I do have a host that is also hardwired.
      I do have armor enabled,  it didn’t change much if I disabled it.
      The url was opened on an iPad on the primary WiFi
      • FURRYe38's avatar
        To get a most accurate result from GRC, you can't have anything else connected as those devices can induce connections of there own and either open or cause ports to be seen by GRC to be incorrectly tested. Why only tesing with one ethernet connected PC and one web browser opened to GRC can test the router out correctly.
