y2k1234njmh's avatar
y2k1234njmh
V7.2.8.5_5.1.21 RBR850 memory leak
I keep tracking RBR850 memory usages via its debug page. I saw it increased 1MB per day. After rebooting it took about 350MB and after online about 10days it reached 450MB so I need to reboot it every month. I hope it can get better in next firmware release.
  • FURRYe38's avatar
    What happens when it reaches 450MB or past this?
    Has a factory reset and setup from scratch been performed since you applied this FW update?
    What all is connected to the router?
    What features are enabled on the RBR?
    Is any logging enabled on the RBR? Debug or Admin logs?
    • y2k1234njmh's avatar
      y2k1234njmh
      Yes. I did factory reset once. I do have about 20 LAN reserved IPs and IoT set 2.4G only debug off and one FTP forwarding all others are defaults. I did not notice performance degrading since I reset when it grows up to 600MB.
      • FURRYe38's avatar
        What happens when it reaches 600MB or past this? Does the system fail?
  • I did one factory reset it doesn't make difference. I just reboot it when it took more than 600 MB. I did not turn log on but I do have lot IoT devices. I have almost 200 devices on the network. After reboot it allows took about 35%cpu and 350MBs
    • FURRYe38's avatar
      What happens when it reaches 450MB or past this? Does the system fail?
        y2k1234njmh
        I did not notice major perform problem yet but I reboot it anyway. I don't feel comfortable bufferbloat latency
